Page 73 of 75
FirstFirst ... 23 63 71 72 73 74 75 LastLast
Results 2,161 to 2,190 of 2222
  1. Erm, no builds anymore ?
    Aug 2013
    Central Germany
    Lately, MABS didn't work reliably due to many many other projects failing before x265; and I didn't have much time; and the RC versions are annoying me on top (there was never a need for such a "postponed version" scheme).
    I will try to finish builds during this weekend...
    Aug 2013
    Central Germany
    x265 3.0 RC+14-46b84ff665fd (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.2.1)
  4. Thanks a lot!
    Aug 2013
    Central Germany
    x265 3.0 Au+4-dcbec33bfb0f (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.2.1)
    Gold!
    Aug 2013
    Central Germany
    There was also, to compare speeds of different compilations:
    x265 3.0_Au+7-cb3e172a5f51 MABS compiled with media-autobuild_suite only (EXE only, no DLL)
    x265 3.0_Au+7-cb3e172a5f51 compiled with custom build scripts to obtain libx265.dll too, running in interactive MinGW32 / MinGW64 shells
    It may have issues with zones.
    Aug 2013
    Central Germany
    x265 3.0 Au+8-31ab7e09a3b5 (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.3.0)
    New 64-bit GCC 8.3.0, and zone issues should be fixed
    Aug 2013
    Central Germany
    x265 3.0 Au+14-c7e5878bdd31 (MSYS2, MinGW32 + GCC 7.4.0 / MinGW64 + GCC 8.3.0)
    3 flavours:
    • "Win32XP" (XP compatibility enabled, should disable NUMA support)
    • "Win32" (XP compatibility disabled, NUMA support should be enabled in Win7+)
    • "Win64"
    AVX2 for normFactor and ssimDistortion
  9. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.0_Au+24-4217e691387c
    (x64, multilib, GCC 7.4.0)
    µChangeLog:
    [x265 patch] analysis: For inter-refine level 1, evaluate smaller CU sizes only when the current
    block is decided as "skip" by the save mode;
    Fix issues in configuring cbQpOffset and crQpOffset for 444 input;
    "Programmers are human-shaped machines that transform alcohol into bugs."
  10. x265_3.0_Au+24-4217e691387c (x64, Multilib, MinGW64 + GCC 8.3.0)
  11. DECEASED
    Jun 2009
    Heaven
  12. x265.exe 3.0_Au+25-39b35ea86283
    ( Multilib, MinGW64 + GCC 8.3.0)
    µChangeLog:
    zone: Fix reconfiguration of RC param
  13. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.0_Au+28-220cdb4328a1
    (x64, multilib, GCC 8.3.0yeah, about time)
    Add codes to support field feature
  14. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.0_Au+31-4583000db964
    Changed the params max-merge to 3, B-intra enabled, limit-ref and early-skip enabled for improved performance for high-res
  15. how I hate it when they change the defaults,...
  16. x265.exe 3.0_Au+32-a46ded2c1411
    (x64, multilib, GCC 8.3.0 )
  17. x265.exe 3.1_RC1+1-10decf67c077
    Release version v3.1
    cll: Fix bug in cli parsing
    Do not call Aligned pixel_avg_48x64 AVX512 code due to segmentation fault.
  18. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.1_RC1+3-3bdf06e3c628
    (x64, multilib, GCC 9.1.0)
    svt: Fix error for newly added param variables
    Decoupled the non-"medium" presets from the effect of new default parameters committed under commit-id 4583000db964.
  19. x265.exe 3.1_RC2+4-b36c03e4e771
    Merge with stable
    Fix double free in zones
    Aug 2013
    Central Germany
    x265 3.1+2-b36c03e4e771 (MSYS2, GCC 9.1.0)
    New options / changes:
       --[no-]field                  Enable or disable field coding. Default disabled
       --[no-]early-skip             Enable early SKIP detection. Default enabled
       --max-merge <1..5>            Maximum number of merge candidates. Default 3
       --limit-refs <0|1|2|3>        Limit references per depth (1) or CU (2) or both (3). Default 1
       --[no-]b-intra                Enable intra in B frames in veryslow presets. Default enabled
       --[no-]fades                  Enable detection and handling of fade-in regions. Default disabled
       --max-cll <string>            Specify content light level info SEI as "cll,fall" (HDR).
       --[no-]cll                    Emit content light level info SEI. Default enabled
  21. Code:
    Okay,.. can someone give an example where this would be useful?
    I mean if '--max-cll "cll,fall"' isn't used cll isn't signaled. If '--max-cll' is used one does want to signal cll and fall. In which case is it helpful to only signal 'fall' ?
  22. Member
    Aug 2013
    Central Germany
    A level of question possibly best asked in the mailing list first? I believe this forum is rather less frequented (if I'm not wrong).
  23. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.1+2-6f7c2ae0d5bd
    Fix crash with aq-motion when aq-mode is disabled
  24. x265.exe_3.1+7-147fb92c5ed5 (MSYS2, GCC 9.1.0)
    cli: fix incorrect CLI help of --[no-]aq-motion
    motion: Implement 3-level Hierarchial Motion Estimation
    motion: Perform ME on each HME level
    This patch does the following:
    1) Perform level-0 ME
    2) Use the MVs as predictor for next level ME
    3) Restrict full-search within a range when HME is enabled
  25. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.1_RC2+10-21db162c8622
    AQ: New AQ mode with Variance and Edge informationhttps://bitbucket.org/multicoreware/x265/commits/21db162c8622677c41a4fc77a14a59eb7326b46a
  26. Member
    Aug 2013
    Central Germany
    @El Heggunte: I would recommend you to clone your local repository freshly, your version numbering is odd. It should be v3.1+8 instead. You seem to miss a tag after the RC2.
  27. DECEASED
    Jun 2009
    Heaven
    Yes, it was strange, but I chose to release the build anyway...
    That's what I always do
    Every time I compile x265 I always delete the x265 source-code directory after the job is done...
    SOMEtimes the simple command "hg clone" is not sufficient to get the latest commit and then I have to add the switch -r commit number...
    So until proven otherwise, I believe the fault is not mine, but of the x265 maintainers at BitBucket
  28. Member
    Aug 2013
    Central Germany
    Hmmm ... ooor ... maybe update Mercurial (hg)?
    I pulled + updated to "tip" (which always gets the latest change, not only from the "default" branch), and the result was version 3.1+8-21db162c8622; MABS keeps updating the used software for me.
    _
    x265 3.1+8-21db162c8622 (MSYS2, MinGW32 / MinGW64 + GCC 9.1.0)
       --[no-]hme                    Enable Hierarchical Motion Estimation. Default disabled
       --hme-search <string>         Motion search-method for HME L0,L1 and L2. Default(L0,L1,L2) is 1,2,2
       --aq-mode <integer>           Mode for Adaptive Quantization - 0:none 1:uniform AQ 2:auto variance 3:auto variance with bias to dark scenes 4:auto variance with edge information. Default 2
       --[no-]aq-motion              Block level QP adaptation based on the relative motion between the block and the frame. Default disabled
  29. DECEASED
    Jun 2009
    Heaven
    I will give a try to that method "as soon as I remember"
    And speaking of MABS... probably I will have to give in to the damn thing, at least for compiling MPlayer :–/
    Thanks for the suggestion! Latest version is 5.0.2, whereas the build I'm using is version 4.8.1... XhmiskosR's latest 64-bit release is version 4.9.1...
  30. DECEASED
    Jun 2009
    Heaven
    x265.exe 3.1+14-f08461fdae33
    (x64, multilib, GCC 9.2.0)
    Latest changes:
    ~Fix: scaling_list_delta_coef out of range.
    ~Add MV refinement level 1,2 and 3.
    ~Based on the MV refinement level, number of search increases.
    ~Reduce QP for the scene changes that is followed by black frames
    ~During a scenecut, the transition from black frames to a different sequence
    ~gives a high QP value. Reducing tune complexity factor for the scene
    ~change in ABR reduces QP.
